nw-hd3 usb cord with nw-hd1?
Discussion in 'Headphones, Earphones & Portable Music' started by mushroom, Mar 10, 2005.
  1. mushroom
    mushroom
    I wonder if the usb cord would work with nw-hd1? Has anybody tried this? Also if anybody could post a picture of this cord? Today I want to Sony's store to see if they have those cords. A lady told my that it's a normal usb cable plus additional adapter? Is it true?
  2. twcheang
    twcheang
    It's a normal USB cable (USB - mini USB) plus an additional adaptar. It works on HD1 but u can't charge ur unit via USB, only for music transfer.
  3. diverse
    diverse
    Jan 21, 2004
    159
    16
    That is correct, i have not used my HD1 docking cradle and only used my HD3 charger and USB cable adapter to transfer with my HD1
  4. d_raux
    d_raux
    Where did you get the HD3's usb adapter ? I'm looking for a second one
  5. mushroom
    mushroom
    thx for the answer.
    So i still need to use the charger to transfer the files?
  6. zano
    zano
    u still need the charger to load files with the usb-cable
    dont waste your money to buy the usb-cable from hd-3
    the cradle from hd-1 isnt that big at all, its just the power adapter...
