nw-hd3 test mode question
Discussion in 'Headphones, Earphones & Portable Music' started by matt_du_man, May 17, 2005.
  1. matt_du_man
    matt_du_man
    May 15, 2005
    26
    3
    hi, just wondering now the volume has been solved by hacking into the test menu, if there is any thing else that can be modified SAFELY from the test menu, i do not want to mess with mine in fear of breaking it, and i was wondering if anyone else has found anything safe, because i cannot find anything else about the test mode posted on this forum
    Thanks in advance for any replies!
  2. matt_du_man
    matt_du_man
    May 15, 2005
    26
    3
  3. watchinthewheel
    watchinthewheel
    i aksed this a while ago and there was nothing i have been on this forum since and there hasnt been anything found, everyone is in the same position as you too scared to find out
  4. matt_du_man
    matt_du_man
    May 15, 2005
    26
    3
    oh well, i can understand why, thanks for replying, now i must go and listen to my nw-hd3 with the sound limiter off and blow up my eardrums lol, goodbyeeeeee :hiya:
