NW-HD3 supports unicode display?
Discussion in 'Headphones, Earphones & Portable Music' started by pagoda, Apr 20, 2005.
  1. pagoda
    pagoda
    I was wondering if the sony NW-HD3 fully supports the display of unicode characters on its screen. I.e., If I have an MP3 with a unicode (korean or chinese) ID3 tag or a unicode file name, could the player properly display the actual characters rather than ????.
    Also, does it depend where I buy the unit in terms of unicode support? Will an unit from the US be able to perform these functions?
    Thanks a lot!
  2. peteyoung
    peteyoung
    Mar 2, 2005
    95
    9
    Staffordshire
    sorry cant help you with unicode but i read from sony that the screen wont display '/' or '\' but mine does! lol
  3. Calza
    Calza
    Mar 6, 2005
    93
    mines does too! :cool: or have you just read something wrong :oops:
  4. cykalan
    cykalan
    it does display chinese, japanese too. korean i am not too sure but probably yes. not sure if it supports mixed chinese/japanese/korean tags in a single file too, so i can't say for sure it have full unicode support.
    for chinese, about 90% of the words can be displayed, but for some reason there are some of them can't be displayed properly.
  5. pagoda
    pagoda
    It's good to know that it can support unicode tags.
    However, are there any problems with transferring files with unicode file names through Sonic Stage?
    Thanks again!
