nw-hd3 Skipping Solved (I think)
Discussion in 'Headphones, Earphones & Portable Music' started by matt_du_man, Jul 11, 2005.
  1. matt_du_man
    matt_du_man
    May 15, 2005
    26
    3
    Ok, i had a lot of track skipping, and i've seen a couple of threads about how the nw-hd3 tracks skip while listning on the move.
    Well, i don't no if anyone has done this, or even thought of it, but, you can defrag your nw-hd3, beacuse it's a hard drive.
    i did this and i have no more track skipping
    For anyone who doesn't know how to defrag, just plug ur mp3 into the computer using the usb, open disk defragmenter, and click on the removable drive, then defrag.
    i am posting this because know one on these boards has mentioned this, and i'm not sure if anyone has ever thought of it (because it such a simple idea)
    Hope this helps anyone who needs it
    Byeee byeeee :hiya:
