NW-HD3 Questions
Discussion in 'Headphones, Earphones & Portable Music' started by Fanboy, Apr 19, 2005.
  1. Fanboy
    Fanboy
    Feb 16, 2005
    25
    Hullo
    I am hoping someone can answer these questions for me. I bought a NW-HD3 at Christmas, and so far I have been v.happy with it. However, I now need to reinstall the OS on my computer, which obviously means reinstalling SonicStage as well.
    1. Will reinstalling SonicStage cause problems using my NW-HD3? Will I have to initialize and format it again?
    2. Has anyone tried this VAIO drag and drop utility for the NW-HD3 that I keep hearing about on forums. SonicStage is a DOG of a program, no doubt about it, and I would prefer to keep my music library organised using Windows Media Player 10. It's a real pain having to keep both updated.
  2. watchinthewheel
    watchinthewheel
    1)yep im afraid so, ss is rubbish, if you have registered your player with sony though, it may work ok, dont expect too much though im afraid.
    2)from what i ahve heard the vio transfer isnt as good as we first thought, I agree ss is pish though, look like we are just gonna have to live with it.
  3. twcheang
    twcheang
    Well, I have no problem with my HD3 after reinstalling SS (must be the same version, otherwise u need to format ur HD3). One thing is I couldn't transfer my songs back to PC because I forgot to backup SS database.
  4. Fanboy
    Fanboy
    Feb 16, 2005
    25
    It seems that to back up the SS database, that it backs up ALL your media files also. I have over 25gb of mp3s, i don't really want to have a second copy somewhere. Is there anyway of backing up the database but not the media files?
  5. camelface
    camelface
    yes....thats what we neeeeeeeeeeeeeeeeed a program that can create a sony database from a winamp playlist or a plugin for windows media that can handle this database technology...
    now where do i start?
  6. magician
    magician
    Dec 27, 2004
    45
    Hi Fanboy,
    One of the many reasons why SS is so bad is that Sonicstage's database is built in Microsoft Access, not a bad DB but not really a solution Sony should be using in a retail product. However this does have advantages for users with some database abilities.
    The actual database is stored in C:\Documents and Settings\All Users\Application Data\Sony Corporation\SonicStage\Packages\ and called MtData.mdb. You may need to turn on "Show hidden files" in explorer.
    I'd guess backing this up and replacing it after your reinstall would leave Sonicstage none the wiser.
    :lesson: I must qualify this by saying i've never used this method to backup the Sonicstage database, never needed to, but i have used it to make Sonicstage do things it just can't do efficiently so i know this database holds Sonicstage's library.
    Good luck
    Magic
