NW HD3, lines on screen? :s
Discussion in 'Headphones, Earphones & Portable Music' started by peteyoung, Mar 29, 2005.
  1. peteyoung
    peteyoung
    Mar 2, 2005
    97
    11
    Staffordshire
    hi, sorry to start another thread but ive not been using my new hd3 long and have noticed that when i turn it off blue lines or sections will appear (like the ink on a calculator) and dissappears after a few seconds to a minute, also if i turn it back on some squares maybe do not show up properly straight away, is this just beacuse of the lcd technology as it is a liquid?
    any explanations are welcome! :confused:
  2. peteyoung
    peteyoung
    Mar 2, 2005
    97
    11
    Staffordshire
    oh its ok now, found out i was turning it off wrong, youre ment to hold down the menu button to turn it off properly, and then you can turn the battery off or press any button to turn it back on, :D
