NW HD3 as External Drive
Discussion in 'Headphones, Earphones & Portable Music' started by shelteringsky, Feb 24, 2005.
  1. shelteringsky
    shelteringsky
    last day i used my nw-hd3 to pass some data from one pc to another. when i copied that information I took it and erased it from the player... but it gives me the impression that it hasn´t been erased at all because when i see the available space in the sonicstage i see less than what should be (i know that since the beggining you don´t have 20gb because a part of it goes to the configuration but...) Where can I see what´s in th player? what folder is the configuration? what folder is the music files? what folder is the data files?
  2. watchinthewheel
    watchinthewheel
    hmmmmm thats odd i put some files onto it and didnt have any problems, they were only small files though. i really hope this isnt an issue with all nw-hd3's cos i was going to use mine to backup a pc im reparing! has anyone else had this problem?
  3. SuperSaiyan4
    SuperSaiyan4
    Feb 19, 2005
    2,245
    48
    +49
    I see a lot of problems going around with the NW-HD3...the NW-HD1 which I got recently knowing the NW-HD3 was out has well no problems such as the ones I have see going around.
