NW-HD3 and playlists?
Discussion in 'Headphones, Earphones & Portable Music' started by n0ne, May 10, 2005.
  1. n0ne
    n0ne
    Can anyone tell me something about making playlists on the hd3? Is it possible to make them on the road or just with your PC? I understand that it's possible to make a fav's list, how does this work and is it comfortable?
    Thanks for any replies, Jeroen.
  2. peteyoung
    peteyoung
    Mar 2, 2005
    95
    9
    Staffordshire
    the only way i know of creating an 'on the go' playlist is to bookmark them. To do this you hold the down button whilst a song is playing and it is added to a playlist called 'bookmarks' you do this with every song you'd like to be on the playlist and then press the mode button repeatedly to cycle through the groups until you come to 'Bookmarks' then all the files you bookmarked are there ready to play. The to un-bookmark a song hold down again whilst it is playing and its gone!
