Nw-hd1 Huge Problem Help!!!
Discussion in 'Headphones, Earphones & Portable Music' started by joesmith, Mar 22, 2005.
  1. joesmith
    joesmith
    Okay, so I live in Canada and bought an NW-HD1 from someone in the US on ebay. Now I installed sonicstage and when I go to transfer songs, it says this:
    This ATRAC audio device is authorized with the music service, but this computer is not
    If you authorize this computer with the music service, you will be able to transfer tracks to the audio device. Do you want to authorize this computer now?
    so I click yes, then it gives me this:
    Non-U.S. Access
    It appears that your computer is currently accessing Connect from outside the United States. Due to licensing restrictions, music on Connect is not available for download from outside the United States.
    Questions? Contact Customer Service
    I dont care about downloading from connect, I just want to be able to transfer music but if I try to it says I need to authorize.
    This is what I have tryed:
    -selecting yes and no
    -Trying to deauthorize (This also gave me the Non-US Access message)
    -reinstalling sonicstage
    Can someone please help, this thing has become useless
  2. joesmith
    joesmith
    oh and I also tryed that vaio transfer program and that says i need to authorize too
  3. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    You need to initialize the hard drive on the player. Do that via the menu, it is at the bottom.
  4. joesmith
    joesmith
    YES THank you so much!
