nw-hd1 docking cradle with nw-hd3
Discussion in 'Headphones, Earphones & Portable Music' started by watchinthewheel, Feb 27, 2005.
  1. watchinthewheel
    watchinthewheel
    hey, iv got an nw-hd3 and was thinking about getting a docking cradle for it, i was wondering if anyone out there has tried the cradle from the hd1 with the hd3? are they compatable? id far rather have a stable cradle than this crappy little clip thingy that comes with it. i read on another thread though that the hd1 and 3 are different sizes, is that true? if it is would it make it incompatable totaly? any advice on this would be great thanks :)
  2. cashback
    cashback
    Feb 2, 2005
    60
    +3
    nah the nd3 is wider that nd1 and dock does not fit
  3. watchinthewheel
    watchinthewheel
    ahhh, well thanks for the info. that sucks though
  4. SuperSaiyan4
    SuperSaiyan4
    Feb 19, 2005
    2,245
    48
    +49
    but the question is can you use the USB cable that comes with the NW-HD3 with the HD1? to charge and transfer music?
  5. watchinthewheel
    watchinthewheel
    i dont see why not, the usb cable itself is a standard cable you can get from any pc store, the actual adeaptor looks the same for the 2 so i dont see why not. i wouldnt want to use the hd3 version instead of a cradle anyway, the only benifit is you can charge it without it also being connected to the usb.
