NVTV MPEG2 TV Tuner - receive Freeview?
Discussion in 'Desktop & Laptop Computers Forum' started by talizker, Aug 21, 2005.
  1. talizker
    talizker
    Aug 21, 2002
    1,037
    +45
    Hello!
    I'm a bit of a novice when it comes to TV Cards... I would like a cheapish card that will enable me to watch and record Freeview (on XP Pro). The NVTV card looks to fit the bill but I can't figure out from anything that i've read if I will be able to get the 30 odd Freeview channels or just regular analogue 1-5?
    http://www.xfxforce.co.uk/product_view.php?sku=PVMP012P
    Thanks for your time :)
  2. DaveP
    DaveP
    It's analogue, you could capture the output from a freeview receiver STB though.
    Dave
  3. talizker
    talizker
    Aug 21, 2002
    1,037
    +45
    Thanks Dave. So, am I looking at something like the Black Gold Media Centre @ £70? Is there anything available that is recommened in the £40-£50 range?
  4. DaveP
    DaveP
    Freeview cards are getting cheaper. The cheapest I've found is this one but before you rush out and buy it do a bit of research.
    I thought about getting this but decided to try the capture route first. My NVTV card should be here tomorrow.
    Dave
  5. meansizzler
    meansizzler
    May 11, 2005
    7,588
    104
    London
    +266
    If your looking for a good Freeview TV tuner I just posted one for sale in this thread,, it's a WinTV Nova-T Tuner....excellent card, but no room left in my case for it..£44 Shipped, which is just under your budget and is media center compatible, hmm..I wish this forum had it's own Buy/Sell thread I don't think nobody here checks the thread in the AV section..
    LINK
  6. The Dude
    The Dude
    May 21, 2004
    5,218
    Beverley, East Yorkshire
    +1,529
    Its V.pricey in comparison... but the Nebula DigiTV is as good as you could hope for, absolutely superb quality and very well featured too... double your ideal budget though.. :(
    Works as a DigiTV server too via the included SW, you can buy the one card and stream all freeview channels to multiple PCs across your LAN.. :smashin:
  7. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    Hi Talizker
    the SweetSpot MCE , combined with MediaPortal comes in at around your budget :)
    regards
  8. talizker
    talizker
    Aug 21, 2002
    1,037
    +45
    Thanks everyone for the info. I did look at the Nebula DigiTV last year but it really is more than I want to spend. I think I looked at MediaPortal a while back but kind of gave up before I started >< I think I will take a look at this tonight then if it fits the bill may pick up the SweetSpot MCE. I am still toying with the idea of MCE 2005 for when XBox 360 comes out (having seen the cool dashboard demo video!) so this will be a good option if I decide to go that way.
