nVidia Graphics with dualview
Discussion in 'Desktop & Laptop Computers Forum' started by DaveP, Sep 8, 2005.
  1. DaveP
    DaveP
    I've just changed from an ATI 9800Pro to an nVidia 6800. I'm connecting one output to an analogue 17" TFT (primary, 1280x1024) and the other to my Sony HS20 pj (secondary, 1280x720).
    When I had the 9800Pro connected I used to drag the dvd player, for example, from the primary screen to the pj screen and maximise it and everything played fine. This left the Control Panel for the player on the TFT.
    The nVidia acts differently. The player shows in both screens. This obscurs the player control and I can't get the cursor back to the 17" monitor.
    Does anyone have any tips regarding using a pj with an nvidia card at the same time as a monitor running a different resolution?
    I've tried Google but there are far too many meaningless hits to be of help.
    Dave
  2. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    hi there, I have just swapped from a 9800 to a 6800 GT as well.
    I use dual view I think. Then I set Theatertek 2 to run on the second monitor (within the options of TheaterTek).
    CaM
  3. DaveP
    DaveP
    Thanks mate, I don't have a copy of theatretek but it looks like I may need one!
    Dave
  4. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    yes, I think you should get a copy. There are so many options that it takes a while to configure but the output to the second monitor alone is probably woth the asking price and hassel of setup :)
    CaM
