Mr_Moo
Established Member
I'm having issues mirroring the imagine, or dual screening. The picture looks perfect, so it's not going to be one of those purple haze issues.
I set the resolution on the laptop, for the LG to it's max, but on the LG screen, there is a large black bar down the left hand side, which doesnt allow the picture to fill this bit. As soon as it hits this bit, it thinks its the end of the screen and projects that bit back onto the laptop (if I move a window around). Also, it cuts off the 'X' that usually appears in the top right hand corner. I can see the 'restore down' and 'minimise' ok.
If I decrease the resolution, the bar gets slightly smaller, but then everything looks a little out of proportion.
Any ideas?
I've seen some known issue about Nvidia and LG tv's, but nothing like this.
I've got some pictures at home on the camera, that I can post to explain myself a little better.
Any ideas?
