NVIDIA Cinemascope Custom resolutions Problem ...
Discussion in 'Home Entertainment Computers' started by Lupin 3rd, Aug 10, 2013.
  1. Lupin 3rd
    Lupin 3rd
    Aug 10, 2013
    Hi everybody.
    I've an HTPC with Geforce GT 630 with last drivers.
    I buyed Nvidia card because I've to create custom Cinemascope resolutions (1920x816 pixels) for my 21:9 projector screen.
    My Full HD projector perfectly support this custom resolution!
    So I've created:
    - 1920x816 @ 60Hz
    - 1920x816 @ 50Hz
    - 1920x816 @ 24hz
    Those resolutions are perfect for my setup.
    Anyway I use my HTPC to play m2ts files ripped from Blu ray.... so I've to create another custom res. [email protected]
    My projector perfectly supports also this last resolution BUT ...
    My problem is that I can't maintain both [email protected] and [email protected] !!
    It seems like I've to choose which one to maintain !
    I hope that I'm using the wrong routine to create custom resolutions ....
    Look at this picture ...
    [​IMG]
    To abtain 23.976 hz I write this frequency in the filed with the red arrow.
    I test the resolution and the system after some second give me a visible image.
    The system automatically change the tiped frequency from 23.976 in 24 Hz.
    Anyway If I apply this res. the pj tells me that is arriving perfect 23.976 freq.
    After that If I try to create a new [email protected] res. the system have strange response and CHANGE my previous 23.976 res. in 24Hz.
    I repeat: It seems like It is impossible to have both 24 and 23.976 res. togheter.
    Any idea about this?
    thank you so much for any feedback.
