Nvidia 6600GT & Sony 11HT PJ Issues
Discussion in 'Desktop & Laptop Computers Forum' started by Nobber, Feb 20, 2005.
  1. Nobber
    Nobber
    Nov 29, 2001
    324
    Hello
    Does any one have this setup
    Sony VPL-VW11HT Projector
    HTPC with Gainward Twin DVI and Svideo (component)
    Nvidia 71.81 drivers have also tried 71.25 & 67.66
    7 foot screen
    WinXP
    I am having major problems trying to get my desktop to look right!
    I have set the desktop resolution to1366*768 native for the PJ with and without powerstrip and am feeding the PJ through svid(component) through my Sony 5000 amp with component leads
    The problem is the desktop does not look pixel perfect and is oversize
    If anyone has any suggestions apart from dumping the PJ and the Nvidia card I would welcome them, also if anyone has this setup could they post all the settings for the PJ and the Nvidia card including things like TV type on the card dot phase on the PJ etc etc etc Thanks for your help, Nobber
  2. bartp
    bartp
    Jan 10, 2005
    70
    why are you using svideo? direct rgb from htpc would be much better. What do you mean by svid(component)? If you feeding your pj via svideo connection from the pc; that looks like complete waste to me.
  3. Nobber
    Nobber
    Nov 29, 2001
    324
    This card has 2 DVI plugs and a svideo connection BUT the s video connector is pinned for component out, I then use the adapter to plugin my 3 component leads
    Nobber
  4. Ar-Jar
    Ar-Jar
    Feb 3, 2005
    45
    You probably have overscan. Projectors (and TVs) do that often. This means that the image is somewhat enlarged and cropped. There are many threads around here about that. I too have a 6600GT and if your's work like mine, you're soon up for the second frustration. The DVD players (I've tried Zoomplayer, WMP and WinDVD 5) don't work when one of the monitors is a set to an HDTV (which it is if you're using the component out). An issue with the driver I suppose. VGA out always seems to work robustly so I'm actually planning to build me a simple VGA to RGB (sync-on-green) converter. There are VGA to component converters too but I happen to have an RGB input on my PJ.
    -A
  5. Ar-Jar
    Ar-Jar
    Feb 3, 2005
    45
    BTW, I'm using the latest official driver, 66.93. Maybe the component out issue is fixed in the beta versions. Have to try that... -A
