nvidia 5700LE (PCI) MCE 2005 issue?? Help!!
Discussion in 'Desktop & Laptop Computers Forum' started by Oasis-GasPanic, Nov 23, 2004.
  1. Oasis-GasPanic
    Oasis-GasPanic
    Sep 20, 2000
    543
    South West London
    +5
    Took delivery of a DabsValue (inno3D) 5700LE PCI G'card last week to go in my HTPC. It went in without any problems and all the drivers (MCE 2005 drivers from Nvidia.com) installed fine. I have no problems viewing any types of video file (inc. WMVHD, DivxHD & .ts) in their respective players (WMP, Divx & VCL) but when viewing any video in FULLSCREEN using the MCE front end i get a black bar down the middle of the screen?? :( . The weird thing is when i "return" to the previous screen the little preview window continues playing the video without the bar down the middle. :rolleyes: Anyone have any ideas :lease:
    Heres my HTPC's spec if it helps:
    -P4 2.6GHz HT
    -256MB PC3200 RAM
    -40GB HDD
    -Inno 3D GF 5700LE PCI 128MB (running @ 848x480-60Hz)
    OH! and i never had this problem when using the crappy "Intel Extreme Graphics" intergrated graphics chip!?!?!?
  2. Oasis-GasPanic
    Oasis-GasPanic
    Sep 20, 2000
    543
    South West London
    +5
    Can anyone help??? :lease: :lease:
  3. Synchro
    Synchro
    Nov 14, 2004
    4,127
    Chester
    +568
    If possible try the card in another PC and get a handle with the same (or as close to as possible) specs.
    If you can't do this, try looking into software problems, maybe the latest driver isnt the best?
    Try the easy trouble shooting options first. It could be a problem on the card.
  4. Oasis-GasPanic
    Oasis-GasPanic
    Sep 20, 2000
    543
    South West London
    +5
    Will Do!
    Cheers Synchrouk.
