mariorainy
I have a problem with Nuvo simplese NV-A4D multiroom amp , sound in 1st zone on left channel has started to drop sometimes but when the sound volume was raised significantly , the channel worked again. Now it has started to do on right channel as well and it is random. I need to turn to volume all the way up and then 2 channels work for some time then they are starting to dropout again so i need to raise the volume . Another thing is that clicking noise, but this happens only very rarely. PSU is 100-240v 50-60hz 85W. Im in Ireland using 240V Outlet.
So for the channels ,is it probably capacitors? Is it fixable ?
Anyone knows why did that happened ? Could it be that im using 240V ? Or this is just normal use.
thank you for help!
thank you for help!
