Nuvi 310 MP3 player
A
AllTalk
Looking to get the Nuvi 310 and use in not only for Nav but also for music so have a few questions - hope someone will oblige
- is there an aux-out headphone socket that I can use to plug in to the aux in socket on my car audio ?
- can you it play ipod (.aac) files ?
- how big SD card can it take, any limit ?
- is there a microphone socket as I want to make full use of the bluetooth phone capability
Thanks.
parbrook
Thanks.
- There is a headphone socket.
- only MP3 audio files, as far as I can remember.
- i'm using a 1GB SD card, but I've read that others are using 2GB.
- no microphone socket, but the built-in mic (and speaker volume) is adequate for bluetooth phone operation.
I believe that you can download the manual from the Garmin website.
multiply
Strange. According to the manual, there is an external MIC socket on the side of the mount.... :confused:
I'm getting mine tomorrow so will find out myself, I guess.
parbrook
Don't know what manual you are looking at, but my nuvi 310 manual says (incorrectly ) that it is a power socket (on right side looking from the front).
However, I can confirm that it is a headphone socket - as I've just tried it.
Makes sense, really - for listening to music.
I've not seen any mention of an external mic socket in my manual.
I made a bluetooth call on mine yesterday.
My wife said that she could hear me OK, but the speaker volume could be a little louder for phone calls.
It does not seem as loud as the nice lady who gives me directions.
parbrook
Humblest apologies :oops:
There is an external mic socket as well.
It is on the side of the screen mount cradle - which you would only use in a vehicle.
The headphone socket is on the main unit - so you can listen to music when the unit it in your pocket.
Similar threads
