Nura, Nuraphone review & Comments
Discussion in 'Headphones, Earphones & Portable Music' started by Phil Hinton, May 29, 2019.
    1. Ed Selley
      Ed Selley
      AVF Reviewer
      Jun 26, 2003
      11,349
      2
      +3,971
    2. MartinH32
      MartinH32
      May 6, 2005
      2,516
      7
      5
      Selby
      +829
      Nice review - they do look flimsy though although they are well made. A little tight though making propitiatory cables.
    3. Nallen0401
      Nallen0401
      Jan 17, 2011
      187
      2
      +35
      Sometimes, looking at your reviews page, it's like your scores are generated by a code function. Something like
      IF Product = UnknownNetflixShow
      THEN Score = 6
      ELSE Score = 9
    4. RudiSt
      RudiSt
      Feb 26, 2019
      186
      46
      Greenwich
      +144
      but is it better than the two leading bluetooth headsets at the moment, i.e the Bose QC35 II or the Sony 1000XM3? A score in isolation without comparing to something in the higher price point is not as useful as comparing with something that is well tested and widely known as a reference point...
    5. Idle Bull
      Idle Bull
      Mar 27, 2014
      278
      46
      +121
      If this works in a simillar way to Adapt Sound on my Samsung S8 then it will definitely make a big difference to the sound quality. I have some cheapish Senheiser BT headphones which were a bit flat and lifeless, but using Adapt sound on my phone really brought them to life (in a natural way). So much so that I don't miss my AKG K550's when I'm listening at work. (and especially not the 3m cable :))
    6. JayCee
      JayCee
      Jan 20, 2004
      23,904
      Lanarkshire
      +2,594
      I bought, tried and returned them.
      The sound quality was no better than my Sony WH-1000XM3‘s and the protrusion that fits into your ear canal I found extremely uncomfortable.
      In addition, the black silicone earpads are a magnet for dandruff.
    7. LAMitchell
      LAMitchell
      Nov 11, 2006
      138
      32
      Hatfield
      +35
      So, Im guessing these have a built in DAC and audio processor to modify the signal according to your hearing profile. How do these compare in sound quality with something such as the Senheisser HD600's after having been 'tweaked' to your hearing? As you mentioned there is some pretty stiff competition out there for that price.
      Personally Im not convinced, I have not had a great deal luck with profiling headphones, crossovers, Digital Signal Processing and the like. All of these modify the original sound and you lose something in the process(ing).
    8. jaymac
      jaymac
      Jan 15, 2003
      1,727
      63
      North Somerset
      +138
    9. achild
      achild
      Jul 14, 2006
      48
      I have a pair and they are very impressive. I tend to wear IEMs anyway and so these offer a wider soundstage and greater bass.
      For reference I use Shure se 535s with custom silicon molds and a pair of beyerdynamic dt 990s. Whilst the fitting will only suit a few they do sound clear, punchy and open
