Number of Hours On PW7
Discussion in 'Plasma TVs Forum' started by forever, Jan 3, 2005.
  1. forever
    forever
    Sep 11, 2003
    793
    +17
    Hi All,
    Does anybody know how to get the pw7 to display the number of hours its been running for?
    Thx
  2. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    You can't as far as i am aware...........................just estimate approx days you've had it and running time.
    Don't get to hung up on the 200 hours period..enjoy it!
    Cheers, Tam
  3. Stuart.Ainslie
    Stuart.Ainslie
    Nov 20, 2004
    127
    16
    Little Clacton, Essex
    You do something like hold down the volume - button on the panel and quickly press the button below input 3 times on the remote and you enter a service menu.
    I can't remember the menu contains the info, might be the third one down, but it lists the amount of times the panel has been powered up and the running hours.
    One of the knowledgable folk on here can probably expand on my vagueness.....
  4. Mr_Wistles
    Mr_Wistles
    Mar 11, 2004
    11,998
    Essex
    +2,945
    Yeah the above method works on a PW6 not sure on a 7.
    You are again correct in saying it is the third option down (again on the pw6), it is labelled SD.
  5. Rambles
    Rambles
    Jul 14, 2004
    8,088
    UK
    +1,067
    I can't get this to work on my PW7 - what do you have to do exactly?
  6. Mr_Wistles
    Mr_Wistles
    Mar 11, 2004
    11,998
    Essex
    +2,945
    If it is the same as a PW6 you hold down the volume button on the tv and press the button below the top left one on your remote three times quickly.
    This will then bring up a menu, select sd from this and it will display total hours and number of times turned on.
  7. Stuart.Ainslie
    Stuart.Ainslie
    Nov 20, 2004
    127
    16
    It does also work on a PW7 - Tired it on mine at the weekend. Only clocked up 205 hours so far.... :(
  8. Rambles
    Rambles
    Jul 14, 2004
    8,088
    UK
    +1,067
    Oh yes, that works - but I don't understand what any of the numbers mean when I am in there? :blush:
  9. Mr_Wistles
    Mr_Wistles
    Mar 11, 2004
    11,998
    Essex
    +2,945
    They are sort of in the middle
  10. Eye in the sky
    Eye in the sky
    Nov 19, 2004
    83
    Hi Guys!
    Need your help urgently if you own a 42PHD7!!! If not, pls help too as colour temp settings may not vary so much from Panny to Panny plasmas.
    When you in the service menu (IIC) settings, could you do me a big favour please!
    I need a couple of Panel W/B etc settings on yoru plasma. Pls see my thread below which I just posted today:
    "Panasonic PHD7 owners! - help needed for colour temp settings in service menu (IIC)"
    http://www.avforums.com/forums/showthread.php?t=175902
    Thanks in advance!!!
  11. Rambles
    Rambles
    Jul 14, 2004
    8,088
    UK
    +1,067
    In the middle it says MTBF Parameters WT29 PT 17
    What's that mean?
  12. Mr_Wistles
    Mr_Wistles
    Mar 11, 2004
    11,998
    Essex
    +2,945
    Turned on 29 times, watched for 17 hours
  13. Rambles
    Rambles
    Jul 14, 2004
    8,088
    UK
    +1,067
    Oh, clever, thanks :D
  14. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    thanks guys........never knew that.................................275 hours so far..............................guessed about right though :clap:
  15. Krance
    Krance
    does anyone know what is it for the pwD7? I tried the above and it doesn't seem to work.
  16. Mr_Wistles
    Mr_Wistles
    Mar 11, 2004
    11,998
    Essex
    +2,945
    I would guess that it does and you are not doing it right. Lisag asked the question also and she has managed to get it to work.
  17. Krance
    Krance
    I tried for about 30 minutes before reaching for the calculator (so many days x so many hours :))
    I have read on another post that the D7 is a business model... could this be a difference?
    Just in case anyone wants to know, this is a normal operation on the business panel. Just use the button under 'on' buton.
    SD menu shows the same
  18. FatBoyii
    FatBoyii
    Jan 5, 2005
    27
    4
    On my PW7 I need to hold down the Vol- button and press the button under the power on the remote 3 times. Button looks like a square with a + in it.
  19. vileda
    vileda
    Oct 15, 2004
    401
    Sunderland, Tyne & Wear
    It definately works on my pwd7, can be a bit awkward sometimes (I hold down both vol buttons on the fromt of the screen and then keep pressing the button under the on/off on the remote until it appears.
  20. offdigital
    offdigital
    Nov 20, 2004
    61
    9
    Works on my 37PW7BX
    Hold the vol - button down on the display itself
    tap button below power button on remote control 3 times
  21. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    sounds silly (because it is) but the first few times i tried this I found that by holding the volume- button I was actually obscuring the remote control sensor with my hand.....now I don't expect anybody else is that daft...but just in case :)
  22. andybond
    andybond
    Feb 15, 2006
    458
    28
    Doncaster
    +33
    I have the tuner box , and for love nor money i cant get it to work ..
    Anyone help ?
    the + and - buttons on my panel dont even register ...
  23. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    you may need to disconnect the tuner, it nobbles most things
  24. andybond
    andybond
    Feb 15, 2006
    458
    28
    Doncaster
    +33
    Is nobbles a technical version ;)
    Thanks ! Ill try it , if anyone else comes up with a solution in the mean time , please let me know ..
  25. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    yes very technical :) but seriously, having the tuner attached does take away a lot of functionality and doesn;t give great picture, you are much better going in to the screen direct.
  26. andybond
    andybond
    Feb 15, 2006
    458
    28
    Doncaster
    +33
    For those folks with a tuner box ...
    As mentioned it does nobble things.
    Intrestingly tho , try pressing the -ive on the tuner box , and hit the square with a plus 3 times ... takes you to a "new" menu , a self test one.
  27. andybond
    andybond
    Feb 15, 2006
    458
    28
    Doncaster
    +33
    When you say bad , how bad ?
    If i get a component board for my pwd7 , and input via my Yamaha 757 will i sit back and go wow ! ? !
    Thanks for taking time to reply to my posts so far ... :smashin:
  28. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    I think you would see definite improvements.....and get back the ability to properly adjust the picture settings
  29. andybond
    andybond
    Feb 15, 2006
    458
    28
    Doncaster
    +33
    Whats a tuner box selling for these days ? ( s/h obviously )
  30. Supersonic72
    Supersonic72
    Jan 10, 2005
    246
    Im up to 3500 hours and 2100 powerups.
    Mind you, its four years this February....so thats barely 900 hours a year, err 2.5 hours a day?
