NuBee question here, regarding denon 2805
Discussion in 'AV Receivers & Amplifiers' started by Arkham Insane, Apr 17, 2005.
Tags:
  1. Arkham Insane
    Arkham Insane
    Apr 17, 2005
    441
    +13
    Hi, ive planned my home theatre now am will get going after my exams have finished. Its a lot expensiver than i though. I was wondering, do i need a seperate amplifier if i buy the denon 2805 receiver? Is it essential, optional or unneccesary? the source will be a denon 2910, speakers canton 2.22 's and the display a sony vpl hs50 projector. The room aint that big at all but big enough for the short throw projector.(Gotta work a couple months to save up!) incidently what do you think about this combination? any flaws? thanks in advance
  2. anotherdavid
    anotherdavid
    Nov 30, 2004
    38
    i would suggest you try it out on its' own first and see how it sounds & performs before looking at an external amp
    you say the room is not too big - the 2805 might be OK.
    I ran my 2805 in a fairly large room and it coped, although I did add a power amp in the end.
    the power supply on the denon is not the largest going around
  3. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    A receiver is an integrated amplifier and tuner together in the one case.
    I am not familiar with the Cantons, but I don't think you would need to bolster the power amp section (that comes with the 2805) with additional power amp.
