NTSC worse than PAL
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by MartinK, Apr 16, 2002.
  1. MartinK
    MartinK
    I'm going to the US soon and as the prices for miniDVs seems much lower there I was wondering if there is any difference in picture quality between PAL and NTSC. As far as I know, the UK models of some cameras have 800,000 pixel CCDs while their US equivalents have 680,000. To what extent is this a major drawback?
    I'm running the camera through the computer and from there on to the TV.
    Thanks,
    Martin
  2. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    By, and sometimes in, the sea
    A number of people in the US use PAL camcorders. For two basic reasons:
    1) 50Hz is more convewnient if you're contemplating going to film.
    2) There is a perception that the quality is better. In part due to the higher resolution but also due to the reputed superiority of PAL colour encoding over NTSC
    For what it's worth I was in a similar position and bought PAL in the UK. I checked prices out there and found they really weren't so much lower that the best deals here.
  3. MartinK
    MartinK
    Where are the best UK deals to be found?
    Martin
  4. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    If you are in London, walking up and down Tottenham Court Road playing one off against another is pretty good.
    Otherwise RGB, Krish or Hi-Fi Confidential.
    Otherwise, when you've made up your mind what you want, do a search on the net to find the lowest price, then if you don't fancy that supplier, find one which will price match.
    Never pay what they ask. Always pay using Barclaycard for safety and post sale price matching and free extended warrenty.
    Hope this helps.
