NTSC VHS to pal
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by JimM, May 13, 2003.
  1. JimM
    JimM
    Jan 14, 2002
    +12
    A friend got married in Vegas and had their wedding videoed but they forgot it would be in NTSC format. I've offered to see if I can help them out but need a bit of advice.
    I think my VCR may be able to cope with NTSC so my plan is to cCapture the analogue signal onto miniDv via my camcorder and then put the now digital signal into Pinnacle so I can add titles etc
    What is going to be the best method of then getting this back to PAL VHS. Will Pinnacle do this or something like TMPGenc ??
    Jim
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,261
    Rainham Essex
    +2,404
    If (and only if as most don't :mad: ) your camcorder has analogue (& DV) inputs enabled then you should be able to copy the VHS directly to the PC only useing the camcorder as a converter. There should be no need to copy to DV tape, putting extra wear and tear on the camcorders heads.
    If you then edit etc as required and then just tell Pinnacle to copy the film back to tape. No conversion should be required as the footage will be in DV format at all times on the PC. Yet again no tape will be required in the camcorder and should be able to go directly to VHS PAL (again useing camcorder to convert from DV to analogue).
    Of course, if you do not have inputs enabled on the camcorder then none of this will be possible.
    Be aware that the quality of playback of an NTSC VHS tape will be lower than a PAL VHS recording on your PAL VCR.
    Mark.
  3. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +93
    Most machines only play back NTSC signals using PAL60, this means you may not be able to capture it to your Camcorder or PC at all, unless you have a machine that will play the tape in it's native NTSC and then capture via NTSC also.
    "No conversion should be required as the footage will be in DV format at all times on the PC. "
    yes but it would be NTSC DV footage, unless you have a way of capturing and converting from NTSC to PAL in the first place.
    You need to get a proper NTSC/PAL converter box, set you back about £80
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,319
    Somewhere in South Yorkshire
    +5,674
    A proper NTSC/PAL converter (ie, one which will fully convert NTSC/525/60 into PAL/625/50 will cost upwards of GBP300.
    The GBP80 boxes convert true NTSC to pseudo-pal (aka pal60) which the playback VCR is probably already doing.
  5. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +93
