NTSC VHS to DVD
Discussion in 'Blu-ray & DVD Players & Recorders' started by Seth Gecko, Nov 23, 2004.
  1. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    Help!!!!!
    I have a VHS tape of a really cool movie (Big Man on Campus) but it's NTSC format.
    I want to be able to backup this tape onto DVD. I have a Sony video, a Panasonic DVD-R/HDD recorder (I'm sure models at this point are irrelevant - if not I'll quote them later).
    I have a SCART cable that removes Macro protection etc - so no issues there with normal tapes - but NTSC is proving an issue. I can tell the Panny to record an NTSC signal - but the VHS is certainly not outputting PAL or NTSC - the best signal I can get gives a "fuzzy" B&W picture.
    HELP!!!!!!! What would I need to do the conversion!?!? :lease:
  2. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Your vcr will output PAL 60,not pure NTSC.Your Panasonic only records pure NTSC.Only Pioneer and Philips dvd recorders will record PAL 60.
    You're buggered!
    You need to get a multiformat vcr(not easy) or a new dvdr(not cheap).
    Standalone digital standards converters are expensive for a decent one :(
  3. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    So, if I just go out and purchase a Pioneer DVR420HS, my "problem" will be solved ?
    Just checking before I go and get one !!
  4. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    If the VHS is copy protected you will need a special Scart lead to remove the CP,but yes,your problem will be solved
  5. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    Sadmuppet - do you know how your TV displays the NTSC? I have NO idea about this, but is it likely it converts it to PAL 50 for display? If so you might just be able to get a signal from the TV to record on your Panny.
    Try playing the tape through to your TV then hit Direct TV Rec on the Panny.
    You may get a msg saying you can't do it, but it's worth a try.
    (US E85s don't have this because hey don't use scarts)
  6. Mark Bennett
    Mark Bennett
    I had a stack of NTSC tapes and copied them onto a Panasonic E30 from a Sony tru multi system VHS deck.
    You need to set the E30 etc to operate in NTSC mode and make sure your getting a true NTSC signal out of the VHS deck and not the modified one that most generic VCRs put out to play on TVs.
    I would offer doing it for you but I don't have any tech to remove macrovision.
    M
  7. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    Pretty sure my LCD outputs pure NTSC if that's the signal it's getting - but I'd hazard that the VCR is outputing PAL60 as was mentioned earlier. I'll give that method a quick shot, failing that I can see the Pioneer swap over being the way. Damn - was happy with the Panny too - but hey I guess if this works then Laserdisk will be the same.....Hmmmmm wonder if AC3 Soundtrack can be done too..........
