NTSC question.
Discussion in 'Blu-ray & DVD discs' started by cas398, Jun 16, 2009.
  1. cas398
    cas398
    Nov 25, 2007
    2,530
    Glasgow
    +184
    Alright everyone.
    My Grandad is looking for the Eddy Duchin Story on DVD.
    The cheapest way for me to get it seems to be Ebay, but it's from South Korea by freight and it say NTSC video. Will this play if his equipment is Pal? I don't think his DVD player is region free.
    It's says the region coding is all so I'm a bit confused. I don't know what the difference is.
    Here's the listing for refference.
    Thanks in advance.
  2. Saldawop
    Saldawop
    Oct 29, 2005
    5,322
    London
    +1,061
    How old is your grandads TV? Most modern TVs can accept an NTSC signal no problem .The disc will play fine on the DVD player.
  3. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    First, make sure it's a legit DVD. It probably is, but it pays to check.
    To echo the above, what kind of TV does he have?
  4. nwgarratt
    nwgarratt
    May 5, 2002
    27,695
    +3,172
    Also, region 2 DVD players have to output NTSC as Japan is also R2 and NTSC. So, it is down to what TV it is. I would have thought it would have to be really old not to do NTSC. I was watching NTSC material 15 years ago on a Sony TV. From what I remember if it is a RGB scart connection then PAL and NTSC is not a factor anyway.
  5. brian s
    brian s
    Feb 25, 2007
    55,586
    Alice in Sunderland,Tyne&wear
    +14,758
    Check his TV manual to see if it has NTSC as well as PAL. If he doesn't have the manual you should be able to find it online. I think most reasonably modern PAL TVs can take NTSC but it's best to check first. Do you have any region free NTSC DVDs in your own collection to check?
    All the best
    Bri
  6. cas398
    cas398
    Nov 25, 2007
    2,530
    Glasgow
    +184
    I'm not sure how old the TV is. It's not an old nager or anything, probably a 28" full screen CRT, one scart socket.
    If I did run into any problems could I rip the film and change the output to PAL? I've got Any DVD. I thought it would be ok considering I don't have to remove any region coding.
    I don't have any region free discs to check first, first timebuying one, and something NTSC related.
    How do I do that apart from takin gtheir word for it?
  7. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    Not easily. It needs some compression and processing know-how - is there no native PAL version available to start with?
    And yeah, you'd have to take your word on it's authenticity, I guess.
