NTSC query...
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dumbo, Feb 4, 2005.
  1. Dumbo
    Dumbo
    Being not technically minded at all, could somebody please tell me if I would be able to watch a DVD bought in Japan? They are Japan Region 2 in NTSC format (whatever that means).
    I have a multi-region DVD player.
    Many many thanks.
  2. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    31,772
    Bristol
    +6,377
    As long as your TV is able to handle a 60hz NTSC signal then you should have no problem playing the DVD but if you told us the exact make and model number of your DVD Player someone should be able to give you more info.
    Also, it doesnt matter if your DVD Player is multi-region or not as Japanese DVDs are Region 2 coded just like UK DVDs.
  3. Dumbo
    Dumbo
    Thanks.
    The DVD player (well, recorder actually) is a Toshiba RDXS32. My TV is a Sony 32" something or other.
    I'll have a go and see what happens.
    Ta
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,710
    Galactica C.I.C.
    +223
    as long as the dvd player is connected to the tv via a scart lead and the dvd player is set to auto mode for the signal type, then you should have no problems.
  5. Dumbo
    Dumbo
    Thank you - now all I have to hope is that the DVD I bought from amazon japan has an English audio option!! - am I being toop hopeful or is it more likely than not that it will?
  6. Miniholic
    Miniholic
    Apr 26, 2001
    3,046
    The Shire
    +398
    If it is an English language film then I doubt you will have a problem, as most Japanese discs feature the original language. Do a search at DVD compare as they give comparrisons across different regions.
