Petey said:Are you running your dvd player through an RGB scart socket on your TV?
Petey said:Usually there is settings on the dvd player itself to configure what signal is being output from the scart socket.
composite
s-video
rgb
Only reason I ask this is because when using an RGB signal the image sometimes shifts to the left, which can leave a tiny black border down the right hand side of the screen. This is not always the case but it may explain your the problem you're having.
To test theory try selecting a different signal for example composite or s-video. If these aren't selectable try plugging the dvd player into a different scart socket than ext1. As I'm guessing that only ext1 is RGB enabled on your tv.
Damo121 said:Will give it a whirl, and see what happens.
Many Thanks Petey
Damo![]()
