ntsc/pal
Discussion in 'Home Cinema Buying & Building' started by grim, Jan 11, 2005.
  1. grim
    grim
    hello i am wondering if ntsc/pal mentioned in the specs of panasonic sc-ht37r means it will play region1 and 2 dvds?
    hope anybody can help.
  2. Strangerer
    Strangerer
    No it just means it will play NTSC and PAL sourced material. The region will still be set unless you buy a multi region machine.Off the top of my head I know that Season 1 of Sex and the City Region 2 was NTSC.
