NTSC/PAL probs with R1 and video projector
Discussion in 'Blu-ray & DVD Players & Recorders' started by stuart1, Jan 13, 2001.
  1. stuart1
    stuart1
    Can anyone help? I have a Region 1 Pioneer DV-K102 DVD player and a multiregion Pioneer LC-10 portable. Whenever I try to view any of my Region 1 American DVDs through my video projector the picture is b+w and rolls. I understand that this is because both players convert from NTSC to PAL 60 and not regular PAL 50. It may also have something to do with Macrovision. What can I do about this? I don't want to have to repalce equipment. Can I buy/make a simple conversion unit?
  2. HT Dude
    HT Dude
    How are you connecting your players to your projector?
  3. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,772
    7
    2
    167
    Birmingham, UK
    +10,686
  4. stuart1
    stuart1
    Thanks, but tried them - they can only suggest the expensive digital standards convertor. The cheaper analogue version is not suitable.
  5. stuart1
    stuart1
    I have tried SCART and BNC. Projector also has 9pin RGB input, but as it is a PAL only projector and I can only supply NTSC or PAL 60 to it I don't think that is the answer. I have been told that I need a £299 digital standards convertor which I don't want. A PAL60 to PAL50 convertor would help, but where can I get one?
