Ntsc-pal 50
Discussion in 'Blu-ray & DVD Players & Recorders' started by dr_mabuse, Jul 21, 2002.
  1. dr_mabuse
    dr_mabuse
    May 4, 2002
    566
    28
    utopia planitia
    +26
    Anyone know which machines can do this? I have only found one, which is the LG 4710, and I can't find any reviews of it. :mad: Anyone got this machine? Is it OK on picture performance?
    thx
    dr_mabuse
  2. kevb
    kevb
    May 16, 2002
    1,099
    41
    About
    +3
    I think most of the samsungs can. I know my old 709 did.
  3. Squirrel God
    Squirrel God
    Isn't it PAL-60? :confused:
    Or is PAL-50 something else? :confused:
  4. dr_mabuse
    dr_mabuse
    May 4, 2002
    566
    28
    utopia planitia
    +26
    PAL 50 is another term for vanilla PAL that is the European standard. PAL 60 is the term for the converted signal that DVD players output from NTSC sources to enable display on European TV's, some of which cannot display pure NTSC.
    Therefore, if you can output an NTSC signal as PAL 50, you can view NTSC material on any European TV as well as archive to VHS or DVD-R as you see fit.
    I have found another player that does this: JVC XV-S302. Anyone got this player and can review it?
    dr_mabuse
  5. Squirrel God
    Squirrel God
    Thanks. I'd never heard of it called that before now. :) But with such few players apparently doing an NTSC to PAL-50 conversion, perhaps that's no surprise ;)
  6. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    PAL = PAL-50
    PAL-60 = Pseudo-PAL
    NTSC
    I think Hitachi players can also do PAL-50, but check first.
    As well some budget players you can get at the supermarket but I wouldn't recommend them.
  7. Confucius
    Confucius
    Feb 1, 2001
    2,151
    Oxford
    +132
    Bearing in mind that it takes some very trick bits of kit (read: expensive, we're talking a one with five zeros here) to convert 'pure' NTSC to 'pure' PAL smoothly, it's best to keep NTSC as such, or go for PAL 60. A £120 DVD player is going to struggle a little to do the conversion acceptably.
    BTW, PAL 60 used to be known as NTSC 4.43 - some less recent televisions may refer to this term in their manuals.
