NTSC or PAL ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by colinpost, Jul 26, 2002.
  1. colinpost
    colinpost
    i have my dvd player (wharfedale 750-chipped) connected to Phillips widescreen tv via the scart 1 connection (RGB)
    when i play some of my region 2 discs (classic B &W films/progs)flashes of colour appear on the screen
    should i set the dvd player to output as NTSC, PAL or Auto ??
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Why don't you just try it - nothing will get damaged by that ...
  3. Squirrel God
    Squirrel God
    R2 disks are PAL and so your DVD player should be set to PAL (or AUTO, try both).
    If it only happens on B&W footage though, it may be a problem with the TV set ....
  4. colinpost
    colinpost
    i should have said region 1 ! sorry.........
    therefore tv=pal
    dvd = ntsc or pal or auto ????
  5. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,606
    Somewhere in South Yorkshire
    +6,147
    If disc = NTSC
    If player = Auto, output is in NTSC
    If player = NTSC, output is NTSC
    If player = PAL, output is either PAL50 or PAL 60 depending on the player. PAL60 is more common.
    If Auto works, use it. If not, set it to PAL. If that doesn't work, you need a new TV or a repair.
