Ntsc Or Pal
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by bornlippy01, Nov 13, 2004.
  1. bornlippy01
    bornlippy01
    HI thinking of buying Panasonic NV-GS200 in the states, but I was wondering if i brought the NTSC version PV-GS200 would if work here on my PC? (i know my TV & DVD are NTSC compat so thats not a prob), Also will the PAL version be better recording/playback Quality than NTSC?
    Many Thanks
    xx
  2. Origin
    Origin
    Don't buy the NTSC version. NTSC is inferior to PAL (fewer lines, more innacurate colour system), and you will for ever be running into compatibility problems. Everything sold in the UK is biased towards, optimized for, or only compatible with PAL, so stick with PAL.
  3. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    With regards the first part of your question. Your PC won't care whether it's PAL or NTSC, it will happily deal with both.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,335
    Rainham Essex
    +2,433
    And with regards to your VCR. The chances are that unless you have a very expensive multistandards VCR it will not be able to record an NTSC signal. Most modern VCR's available in the UK these days can play NTSC recordings, but they will be at a far lower quality as the VCR is doing the conversion internally and will not do a great job. The chances are that the picture will be quite noisey due to the conversion. But if you need to put you footage onto a VHS tape for somebody then you are as I said very unlikely to be able to so from an NTSC camcorder onto a PAL VCR.
    Mark.
  5. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Must take slight 'issue' with 'Origin'. Nitpicking I know but in a 'studio' environment in many ways NTSC is superior to PAL - more accurate colour analysis and rendition of colours - PAL is cut down from NTSC in this respect. However, I agree 100% that once it is transmitted via analogue then it can indeed be awful. Regards, yt.
