NTSC on latest crop of Pannys / Tosh - any problems?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Lighty, Oct 11, 2004.
  1. Lighty
    Lighty
    Mar 7, 2002
    3,060
    East Yorks
    +172
    hi
    i am just about to buy my first dvd recorder....
    i have a mixture of R1 & R2 discs - about 60 / 40, and would like to know if there are any issues with R1 discs.....jerky pans etc
    (just snapped up a jvc tha75 all in one for surround sound from RS - noticed jerkiness in R1 pans - sonething to do with 50 / 60 Hz ?? - won't use it if dvd recorder has prog scan though !!)
    Priorities are -
    1. good analogue signal for TV
    2. Prog scan for dvd / etc - i am going to buy a prog scan lcd - probably a 26 inch
    3. wife friendly use!
    4 Occasional camcorder editing with a bit of pc swapover
    thanks guys
    i'm almost set on a toshiba xs32 reading the comments on here .........
  2. Nelviticus
    Nelviticus
    Jun 21, 2003
    473
    Hitchin
    +69
    I can't comment on the Tosh but can confirm that the Panny E95 does all that you want - prog scan, easy to use, DV input. I haven't noticed any problems with R1 discs, but I suggest that you take a disc along to a retailer and ask if you can try it out.
  3. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Tosh won't record NTSC.
    If the current Panasonic range is the same as their earlier ones,I'm sure many users would be surprised to realise that Panny outputs NTSC in PAL 60,not pure NTSC.Enabling that requires altering the tv system setting,but that needs changing back when recording PAL.Its worth noting that even if you leave the machines(of all makes) on PAL,while playing an NTSC disc,you won't be able to record in PAL.Annoying if you use your recorder for viewing aswell.
