NTSC LCD to PAL for Sky
Discussion in 'LCD & LED LCD TVs Forum' started by stuartjprice, Mar 15, 2005.
Tags:
  1. stuartjprice
    stuartjprice
    Yikes!
    Just discovered my Sharp LCD with TV tuner is NTSC!
    Is there a way of converting it to PAL so I can receive Sky?
    Cheers!
  2. jimg
    jimg
    Jul 4, 2004
    826
    +58
    What model do you have and does it have scart input? the model number should LC-26GA4E or similar. If it ends in U then it is a USA model.
  3. stuartjprice
    stuartjprice
    No it doesn't have scart and it's model no. LL-M15X1U!
  4. jimg
    jimg
    Jul 4, 2004
    826
    +58
    Well you have a USA import, so I am afraid you are stuck! :rolleyes: :eek:
  5. Alan111S
    Alan111S
    Oct 28, 2004
    78
    If I were you, I'd get a wireless Video Sender. They work using SCART, which you don't have. But you could easily get a cable with SCART at one end and Composite Video (Yellow RCA) plus Stereo RCA plugs at the other. Plug the SCART into the Video Sender and the three RCA cables into the TV. The Composite signal will be crap, compared to RGB SCART but miles better than the RF signal you were originally going to use. Another bonus is you'll get Stereo sound as well!
    Only downside is that your Sharp won't pickup normal Analogue channels.
  6. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Are you sure the set will not accept 50Hz PAL throught any of its inputs, ie s-video? It doesn't matter whether the tuner is NTSC or not if you want to use a STB. Another solution, albeit more costly but much better quality is a scaler that handles frame rate conversion or standards converter.
  7. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,804
    Somewhere in South Yorkshire
    +6,415
    Seems a bit of an excessive way to connect a $ky box to a nearby TV.
