NtSC Interference on plasma
Discussion in 'Plasma TVs' started by steevs, Sep 28, 2003.
  1. steevs
    steevs
    Jan 3, 2003
    2,874
    68
    wxm
    +71
    I have a bit of a problem with my screen, although not totally happy with my PQ it is pretty good on dvd via component, only problem is region 1 dvd, this seems to attract a fair bit of interference ie diaganol lines which is very offputting. I spoke to my manufacturer who has informed me it is caused by some kind of electrical interference in my house somewhere. I have never heard of this problem so I was just wondering if any of you guys have come across anything similar? Also if you have short of tearing all my wiring out is there anything I can do to combat it?
    Steve
  2. briandzo
    briandzo
    Dec 12, 2002
    373
    19
    Newbury , Berkshire
    make sure your display is actually displaying a 525 line ntsc image, rather than your dvd converting your region1 and displaying it as pal. As standards conversion within the dvd players are usually very bad.
    therefore goto your dvd menus and make sure dvd is set to 'multi' or 'auto detect' in display options.
