NTSC enabling on sony tv's, how?
Discussion in 'General TV Discussions Forum' started by s9s, May 21, 2002.
  1. s9s
    s9s
    As the title says, I need to check if NTSC lock is on my dads tv set, apparently on Sony set you can disable/enable it as I am having problems with some of his NTSC discs, the set by the way is KV32FQ75 , and no he has no problems with it! Rather a stunning picture if Sony mnaged to address all the faulty ones.
    Anyhows, since i dont have access to the manual (different locations) any help appreciated, cheers.
  2. Squirrel God
    Squirrel God
    NTSC should be accepted without problem.
    What do you mean by "problems with some of his NTSC discs"? Can you be more specific?
  3. s9s
    s9s
    My R2 PAL discs work fine, only his ntsc discs dont (all black and white, flicering, sound is ok). I remember once changing the AV setting on one of his older Tosh tv's from s-video to normal so as the second scart could be used by bro's playstation, im wondering if thats what needs to be done here.
  4. Squirrel God
    Squirrel God
  5. s9s
    s9s
    Cheers Squrraial
    Just phoned Sony, they told me that my dads tv has to enabled to s-video/ntsc by an engineer! B4 i go to comets all guns blazing, anyone else heard of this??
  6. Squirrel God
    Squirrel God
    Have you tried it using RGB and/or composite? PAL 60 on S-Video? (Make sure DVD player is set accordingly)
  7. AndyFox
    AndyFox
    This is noted on the techtronics website
    FS70 Techtronics
    At the bottom it says how you could do it yourself if you so wished - with care of course.
    Andy
  8. Squirrel God
    Squirrel God
    How's he going to get the car inside his dad's house? ;) :p :D
  9. AndyFox
    AndyFox
    :D :D Thanks :D
  10. Squirrel God
    Squirrel God
    Couldn't resist, sorry :D
  11. s9s
    s9s
    Thanks for the help, will check setting of dvd player (dav s500) when im round nxt time. Bit of a bummer, but at least I got answers.
    Regards
