NTSC DVD Recorder??????????
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jazzypap, Aug 30, 2005.
  1. Jazzypap
    Jazzypap
    Hi :hiya:
    I live in the UK and have a NTSC mini DV recorder and I'm looking to record the NTSC videos I've recorded of my little boy's birthday party onto a DVD disc via a DVD recorder.
    If I connect the mini DV camera to the DVD recorder via i-link and record the videos directly onto a DVD disc, will these play on multi-region DVD player?
    As I understand it and I could be very much mistaken, just because my multi-region DVD player will play Region 1 DVD's, this doesn't necessarily mean that the multi region DVD player will play an NTSC DVD disc????
    Forgive my being a complete novice - all I want to achieve is to record my NTSC videos onto a DVD disc!
    Thanks for looking and I hope someone can help!
    Paul
  2. shortround
    shortround
    Sep 3, 2003
    418
    28
    +43
    it should say in the dvd recorder's manual if it will record ntsc sources or not. if it can, then i would presume it can record ntsc through all its inputs including the i-link.
    as for playback on a normal dvd player, it doesn't matter about region coding as this does not apply to consumer dvd recorders when making home recordings (all recorded discs will be region 0/region free). the only important thing is whether the dvd player will playback ntsc sources, and i've yet to see a UK model dvd player that can't do this. it will either convert the ntsc disc to output pal or it will simply output the ntsc signal natively (in which case your tv will need to be ntsc compatible, 99% of modern tvs are).
  3. AthensDion
    AthensDion
    Jul 13, 2005
    9
    What drand model is your DVD recorder?
  4. Jazzypap
    Jazzypap
    I'm not sure which DVD recorder to purchase as there appears to be a plethora of them on the market and I'm becoming increasiningly confused!
    I do know I'll be looking for model with the i-link connection and is NTSC recordable/playable.....
    ps thanks to shortround for this information, which I've found really useful.
    Paul
  5. AthensDion
    AthensDion
    Jul 13, 2005
    9
    The pioneer DVR 530H or the 433H will do the job. Good luck.
  6. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
    Also the Pioneer DVR-510Hs (Should find one cheap - try getting a region 3 one)
    Mines has both PAL and NTSC i-link input. :thumbsup:
    When recording NTSC the disc will be made in NTSC.
    If your display doesn't support NTSC, when playing your disc it will convert the output signal to PAL. :smashin:
    What's important when you are purchasing a PAL based recorder is that it will accept i-link NTSC. Don't ask if it will play NTSC or even record as the analogue connections can usually do this. You need to be specific about your DV connection. :lesson:
    Hope thats of some use. :)
  7. Jazzypap
    Jazzypap
    Thanks for this but am I wrong in assuming that if the DVD recorder is capable of recording an NTSC source e.g. mini dv video, it will record the source as NTSC wherever the input source, be this through the i-link connection or some other input source, as per shortround's comments above?
  8. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
    You need to make sure that it can do NTSC DV input.
    When I was searching the PAL recorders at that time didn't.
    Think about getting one from the US which will be native NTSC,multi-voltage, do
    PAL and be multiregion as standard. You can even get ones with DVI and upscaling too 1080i, try searching for a Toshiba RD-X5.
  9. Jazzypap
    Jazzypap
    I tried a search for this model but only reveals lots of Japanese sites and nothing on a UK search!
    Can anyone suggest alternative models to the Toshiba RD-X5?
    I would have thought that a DVD recorder that records both PAL and NTSC formats would be fine e.g. Pioneer DVR433H or Pioneer DVR530H, am I mistaken?
    Paul
  10. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
  11. Jazzypap
    Jazzypap
    After much thought and research, I decided to go with the Pioneer DVR433HS. I contacted Pioneer Tech. people who confirmed that this unit will record an NTSC source input at the IE1394 port - all I have to do is change one of the settings to 525 lines (NTSC).
    Thanks to all for help and advice you've given.
    Paul
  12. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
    Nice player & good price-good call! :)
