NTSC DVD playback problem?
Discussion in 'Xbox Forums' started by pablo99, Mar 12, 2006.
  1. pablo99
    pablo99
    Oct 15, 2004
    384
    Aberdeen
    +16
    Maybe a niche problem here but anyone else tried playing an NTSC DVD on their XBOX360?
    I tried it last night and found that the picture froze and stuttered all the time. Like every second! Audio is perfect.
    It'll play PAL DVDs okay. The NTSC disc is a region free music concert. Only tried it on the 360 cos to play it on my DVD recorder I have to change the TV output to NTSC from PAL in the settings. Just hoped the 360 would have saved the hassle.
    Pablo
  2. Fightclub
    Fightclub
    Aug 3, 2002
    603
    Kent
    +43
    Hello mate! Its does the same thing with region 0 NTSC discs on mine! Its probably because the dvd player side is not NTSC progressive scan?
  3. pablo99
    pablo99
    Oct 15, 2004
    384
    Aberdeen
    +16
    Cheers Fightclub :thumbsup:
    Think its a flaw that might get fixed?
    I thought it wouldn't work at all initially. Then when it played all the warning speil at the start and even the DVD menu was fine I thought I was on a winner.
    How is yours connected to the telly? I use RGB scart. The component sockets are busy with the DVD recorder.
    Just wondered if that might make a difference?
  4. Mad Jack
    Mad Jack
    Oct 7, 2004
    453
    +40
    My NTSC Maradona DVD does the same thing on my 360 connected to an LCD TV via component lead. It also did the same thing when I tried it on my Brothers 360 connected to a CRT via RGB SCART.
  5. DragonOfSilver
    DragonOfSilver
    Dec 23, 2005
    1,085
    48
    +73
    I think its just a case of crap video player not properly compensating for different framerate to output, the video player used in most games seems to be as bad at playing back 30fps video at 25fps.
