NTSC discs & stripey image
Discussion in 'Blu-ray & DVD Players & Recorders' started by Supersonic72, Mar 23, 2006.
  1. Supersonic72
    Supersonic72
    Jan 10, 2005
    246
    Heya all..
    Just wanted to bounce an idea around as regards upgrading an old bit of kit..
    I've got an old Panny RV-31 DVD player, its ok, but I have a couple of discs that I play which are NTSC format, and the image I get is a stripey mess of colour. The settings allow me to change to NTSC, but i get a b & w image instead which isnt really a solution. The display is a Panny PW7, conntected via the SCART board with quality Thor cabling...
    It makes a shocking sound when I play these discs, as the mechanism must be really struggling, so last night me and the missus thought a DVD recorder would be a good idea right now...
    So, looking at a Panny E-65 DVD recorder, as theyre going cheap right now, but would this play said discs. It looks like i have a batter range of SCART outputs than the RV-31 which doesnt even have RGB output!!
    Any ideas welcome!
  2. stevelup
    stevelup
    Aug 13, 2002
    6,795
    Swindon
    +1,300
    The Panny SCART board is definitely fully multistandard and should be able to accept anything you throw at it.
    You could try pushing the input button a couple of times on the Panasonic remote as this switches between S-Video and Composite/RGB.
    Steve
  3. Supersonic72
    Supersonic72
    Jan 10, 2005
    246
    Thanks for that...
    Just downloaded the E-65 manual, and there is mention of whether the TV is multistandard, PAL or NTSC, so youre saying its multistandard? (page 17).
    That'd make life easier!
  4. stevelup
    stevelup
    Aug 13, 2002
    6,795
    Swindon
    +1,300
    It's definitely multistandard. But it's also not the best way of connecting a modern DVD recorder to your panel.
    You should probably think about getting a component input board for your panel at some point.
    Steve
