ntsc discs on Dv139
Discussion in 'Blu-ray & DVD Players & Recorders' started by newbie265, Aug 23, 2013.
Tags:
  1. newbie265
    newbie265
    May 21, 2003
    493
    Rochester, Kent
    +7
    My arcam Dv139 has stopped showing the picture on NTSC discs for some reason pal ones seem fine, for example on my Supertramp Live Dvd, I can hear the music through the system but the tv doesn't pick up the picture the same on the kettleworz dvds, its run through a HDMI lead.
    Any ideas people :lease:
  2. Damian1978
    Damian1978
    Jul 15, 2000
    4,519
    107
    Fleetwood, Lancashire
    +262
    Is Auto enabled on TV System in the Setup menu?
    With the 5.06 firmware I get the odd HDMI handshake glitch when the player switches from PAL to NTSC.
    Try selecting NTSC from that option and see if it plays.
    You could always reset the player by pressing Eject then typing 4792 (I think). This resets the multi region capability.
  3. newbie265
    newbie265
    May 21, 2003
    493
    Rochester, Kent
    +7
    the code worked many thanks :clap::thumbsup:
  4. Damian1978
    Damian1978
    Jul 15, 2000
    4,519
    107
    +262
    Good good :)
