NTL upgrade
Discussion in 'Cable TV & Virgin Media TV' started by Darren_L, Jul 13, 2001.
  1. Darren_L
    Darren_L
    Jun 30, 2001
    96
    England
    +3
    FROM WWW.LETSAUTOMATE.COM www.letsautomate.com/prontouk.cfm?cfid=40217&cftoken=16...
    >IMPORTANT NOTE only for UK Digital Cable viewers:
    >There are three types of Digital Cable viewing box
    >that we know of. There are two models made by Pace -
    >D1000T and D1010T. These use NON industry standard
    >infra-red (they use infra-red known as IRDA standard
    >which is used by computer peripherals to
    >communicate). Pronto can NOT learn these codes (and
    >no other learning remote can either).
    >However the model DI4001N can be learnt without
    >problem.
    >Sky-Digital, On-Digital, and analogue viewers are NOT
    >affected by this problem, and Pronto will learn these
    >products (and just about any other product) 100% okay
    The One-For-All Mosaic will work with the IRDA boxes (according to an email from One-For-All)
    Make sure you get concrete confirmation from NTL as to which box you'll get. I'm currently "in negotiations" with NTL as I'm considering leaving them and they want me to stay.
    The NTL digital service is actually pretty good. The premium channels are the same as Sky, but you don't seem to get Sports Interactive where you can change angles and focus on players etc. The basic channels are similar wih one or two channels exclusive to either Sky or Cable.
    If you live in certain areas then you can get high speed broadband internet via NTL Digital (for an extra £25/month).
    If you're gonna stay with NTL (and I'm not yet convinced Sky Digital is better) then I'd go to digital - more channels and better picture, together with onscreen prog guide etc.
  2. kennydies
    kennydies
    May 7, 2001
    191
    UK
    +4
    Sorry to bring up NTL again.
    I am thinking of upgrading from analog to digital on NTL. As I use a Marantz 5000i to control everything I was wondering which boxes don't work with a universal remote??
  3. kennydies
    kennydies
    May 7, 2001
    191
    UK
    +4
    Next question then. Does anyone know if Powermids are compatable with the non standard IR codes?
  4. Darren_L
    Darren_L
    Jun 30, 2001
    96
    England
    +3
    What's "powermids"?
    The only way that I can find to get the Pronto/Marantz remote to work with the Pace 1000 & 2000 boxes is to buy a TIVO, and an adaptor (£30 extra). This adaptor only works with the TIVO, and allows the TIVO to control the STB. Problems is that £630 (incl lifetime subs to TIVO) is a LOT of money.
  5. kennydies
    kennydies
    May 7, 2001
    191
    UK
    +4
    A powermid sends IR signals somewhere else in the house. I ran the output from the STB to the main booster which that branches off to 3 TV's. By using the powermid I can control the STB from anywhere in the house.
