NTL to DMS II connections ...
Discussion in 'Cable TV & Virgin Media TV' started by Dave_M, Mar 7, 2005.
  1. Dave_M
    Dave_M
    Jan 31, 2005
    54
    Harrow
    I'm considering buying a DMS II, but have concerns over the picture quality I could get into it from my stb.
    My stb is a Pace 1000 series (NTL) and outputs either composite or RGB over a Scart connection. I understand that the DMS II has Composite and S-Video inputs.
    Does this mean that I'll need to use composite to get the signal from the set-top box to the DMS II, or is there a way to use the RGB out over Scart and convert that to S-Video? Or is there any way I can get an RGB signal directly into the DMS II?
  2. Werner
    Werner
    In another thread, mention was made of an rgb-->svideo convertor for about £60. I havent seen these things yet, so cant supply any more info. Failing that, you would need to fall back to composite, or even rf.
  3. Dave_M
    Dave_M
    Jan 31, 2005
    54
    Harrow
