ntl stb to pc
Discussion in 'Cable TV & Virgin Media TV' started by systemsdead, Mar 31, 2005.
  1. systemsdead
    systemsdead
    Jan 19, 2005
    7,041
    grimsby,canada
    +1,414
    hi peeps i was wondering if this was possible,can i run my stb to my pc monitor which is lcd with 2 outputs dvi and and normal blue one,if so what equipment would i be looking at for the job,and would i be able to get some kind of splitter to run it from the modem, which is under the desk instead of having wire from the tv to comp which are in seperate rooms any help apreciated
  2. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    the way that you would do that is with a PC capture card. It allows you to use your PC monitor as a display for your set top box, either in a window or full screen. Plus there are a number of other benefits as well..
    have a look at http://www.pluggedin.tv/sweetspot/support/faq.html#2a for some ideas..
    regards
  3. systemsdead
    systemsdead
    Jan 19, 2005
    7,041
    grimsby,canada
    +1,414
