NTL Remotes designed by a leftie!
Discussion in 'Cable TV & Virgin Media TV' started by Gemini-Phoenix, Aug 18, 2005.
  1. Gemini-Phoenix
    Gemini-Phoenix
    Jun 23, 2005
    392
    Ipswich
    +13
    Don't mean to be a one track record here, but after deciding that various Sony portable music players (Mainly Mini-Disc's) were designed by a leftie, my attention was shifted to my NTL remote...
    Everything about it screams "Leftie" ~ I don't use it much, but when I do actually have a spare hour to sit and veg in front of the Tv, I find it quite painful to use in my right hand. All the controls you mostly use are on the right hand side (Such as the channel up / down select), but to use them comfortably, the remote really needs to be sitting in your left hand with your left thumb used to control it...
    If you try to control it with your right hand, you find that it has to be carefully balanced for you to apply the right pressure to the required buttons.
    Another flaw I find using the NTL remote is the fact that the numbers are down the bottom... Now the NTL remote is a funny shape underneath, and this makes it difficult to hold whilst pressing numbers with one hand. Thus, it usually takes two hands to enter the channel number you require...
    Of all the designs they could have come up with, and this is the best? At least Sony remotes are ambi-dextrous, and can comfortably be used in either left or right hand
  2. Grobnic
    Grobnic
    Jun 21, 2005
    115
    16
    Chelmsford
    Lefties rule OK :thumbsup: :thumbsup: :thumbsup: :rotfl: :rotfl: :rotfl:
  3. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,600
    2
    In a secret location with Jennifer Lawrence
    +9,313
    At last, things are turning to our side of the force!
