NTL Remote
Discussion in 'Cable TV & Virgin Media TV' started by J D, Mar 19, 2006.
  1. J D
    J D
    Jul 18, 2005
    42
    Does anyone know how to setup my NTL remote to control my TV volume? Since I've had a new remote I've lost the function.
  2. MERC4
    MERC4
    OK - Press HOME button.
    select SETTINGS AND SERVICES
    select TELEWEST HELP AND INFO
    select TV
    select TROUBLESHOOTING
    select REMOTE CONTROL
    select FIND MAKE OF TV AND CODE
    THEN - FIND YOUR TV CODE AND WRITE IT/THEM DOWN
    Press BACK button to read instructions.
    :thumbsup:
  3. J D
    J D
    Jul 18, 2005
    42
    Thanks, think it's different for NTl though as I don't have a Home button, have tried settings and can't find it in there.
  4. MERC4
    MERC4
    I'm with TELEWEST, but I thought it may be the same as NTL ?
  5. IronGiant
    IronGiant
    Jun 7, 2003
    66,373
    +46,563
    My new NTL remote came with a comprehensive leaflet, assuming it's the same new remote, I hope I can help you out.
    The first thing we need is the brand of your TV so I can post/send you the relevant codes from the leaflet.
    The instructions start with " hold down the "*" and "setting" key until the standby indicator light at the end of the remote flashes green twice..."
    So I will scan in all the relevant instructions to post/send to you :)
    Dave
