ntl problem
Discussion in 'Cable TV & Virgin Media TV' started by jmack, May 1, 2003.
  1. jmack
    jmack
    when i press the select button to get a write up on the program that is showing there is nothing ? been like this for few weeks now. anyone alse have this problem ?
    i`m in cardiff if that helps:D :D
  2. pinatubo
    pinatubo
    I have also seen this problem on occasions - try rebooting the box.
  3. jmack
    jmack
    how do i do that?
  4. taimur
    taimur
    Jan 9, 2003
    512
    19
    Glasgow
    I too had that problem recently. I unplugged the power supply from the back and plugged it back in again and it's OK now.
    Actually, this type of problem is all the more reason for using an HTPC and something like myHTPC and digiguide.
  5. Kevo
    Kevo
    Aug 23, 2001
    5,358
    Manchester
    +145
    Rather than unplug and plug in again simply press (on the box) OK, Left menu and TV buttons together to re-boot.
    This workd with my Pace 1000 model.
