NTL Pace STB Output Choice
M
mattrixdesign
I need to connect my NTL STB to my JVC W/S TV.
However, the TV only has 1 X SCART (RGB), 2 X SCART (S-VIDEO/STANDARD), 1 X S-VIDEO.
SCART RGB - connects to my Toshiba DVD (reading on this forum I believe my Tosh may out put better on S-Video??? If so which, S-Video via SCART or via S-Video Connector :confused:)
SVideo Connector - connects to my PS2 (thing is the TV wont auto detect when I switch on my PS2:( )
This leaves my STB going through standard SCART, picture is OK, but not great. There are only two outputs options on the NTL menu, RGB or Composite :rolleyes:
OK, I know Sky is better, I wish NTL would update their boxes and give us digital out etc. But Sky just aint an option as NTL is a better buy with BB and phone line.
What to you wise ones advise... :lesson:
hornydragon
NTL on RGB if not using a VCR you can DVD>ntl>TV AV1 all on scart both set to RGB when ntl is off or instandby DVD will be displayed. SET ntl for WS 16:9 as well.
M
mattrixdesign
Thanks for reply, not sure I understood your message.
The STB is set to WS 16:9
I guess you are saying plug the DVD player in to the STB, then the STB into the TV? Should I expect to loose quality when watching DVDs?
hornydragon
shouldn't really notice it. or set DVD to output S-video and use AV2 (if you cant get DVD to output S-video over scart dont worry all you need is a cable)
M
mattrixdesign
Well I did read that Tosh DVD players can perform better on S-Video. I will try SVideo via SCART tonight, alternatively I will try it via S-Video connector, but I dont have a decent S-Video cable.
I did try to out put my PS2 to S-Video (via SCART) but picture was crap.
🎬 Across the Spider-Verse, Fast X, Covenant, Sisu, Changeling 4K, Lighthouse 4K, Quantumania 4K & TV
Back
