NTL pace ditv1000 digital set top box + plasma
Discussion in 'Cable TV & Virgin Media TV' started by markevo, Nov 10, 2004.
  1. markevo
    markevo
    Aug 19, 2004
    32
    liverpool
    HI ALL
    having just spoken to a ntl tech, i was told to reconsider buying a panny plasma as the pace ditv1000 digital set top box has compatabillitie problems with plasma screens and probly wont work.
    As anyone set up a pace ditv1000 ntl box to a plasma,? if so how,what cables and what was the outcome ?
    should i risk it or just look at alternatives ?
    all i want to hook up is the digi box and the dmre55, will putting the digi box thriugh the dmre55 get rid of the problems ? the digi box has no rgb output.
    any help more than welcome.
    Mark
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,687
    UK
    +116
    NTL are talking rubbish as usual!!! :mad:
    You can use scart or check out the RGB2VGA or RGB2YUV converters from www.js-technology.com
    NTL box does have RGB output (mine does anyway...)
    JJ
  3. petulia
    petulia
    May 21, 2004
    20
    3
    To get RBG o/p on an NTL box go in the menu then options and choose tv settings your choice is in there.
