NTL Pace Digi box - RGB?
Discussion in 'Cable TV & Virgin Media TV' started by steverussell, Jan 22, 2003.
  1. steverussell
    steverussell
    Can anyone help, I have a PACE digital TV box - supplied throgh NTL.
    I am not sure of the specific model no. but it has only two scart leads at the back (no other connections at all).
    Before I buy my cables, I wondered if anybody knew whether one of these was an RGB - neither are laballed as being so.
    Many thanks for any help!
  2. steverussell
    steverussell
    Moldle no.......
    On looking on the bottom of the box, It seems that the modle no. is a Di4030
  3. steverussell
    steverussell
    modle????? perhaps I mean MODEL !!!
  4. Adlopa
    Adlopa
    Nov 25, 2002
    74
    If it's the same as my TeleWest Pace box (4000 and something, last time I looked), it does support RGB but it needs to be enabled in the setup menu.
  5. steverussell
    steverussell
    Yeah, I thought that might be the case. I am probably being very stupid but I can not seem to get into the setup menu- How do you do this?
    (N.B. the model is DI4010-N - How hard can it be to read a number!! This is definite this time though!):clown:
  6. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    you want tv guide, settings, tv screen settings, bottom box selects RGB or composite.
  7. steverussell
    steverussell
    Yep, Brilliant, Got It!!!
    Thanks for that. One last question, if I am using an RGB scart into 3 component video ouputs from the box (for use with a projector). How do I get my audio out?
    Do I use the other scart on the box?
    Many Thanks.
    Steve.........
  8. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Assuming you have no phonos, yes. If you need it for VCR then Maplins, Keene, and others sell a breakout scart. It has a plug and pas-through socket, 21 pin, and on the top is stereo audio, composite vid and probably s-vid, but don't get any ideas there, the s-vid won't work...
  9. steverussell
    steverussell
    MAW - Fantastic - Just the jobby. Thanks.
    Where is the place to get good value/quality RGB/SCART leads.
    I have seen on Keene.co.uk that they do some that do not look a too bader price - any experience?
    I know you can spend a lot of money on leads (been looking at the SUPRA AV3) but if an un-named model is going to be nearly as good then I think that will suffice!
    Cheers.................
  10. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Personally I find a scart at around £15 odd quid, perhaps £20 is as good as you can tell no more difference, unless your TV is huge.
  11. Fernsehman
    Fernsehman
    I got one like this which I've never seen anywhere else. It's fairly thick (usually a good sign) and it has little projections on the Scart plugs that allows them to clip into the sockets. They need quite a firm pull to remove so your spouse won't accidentally dislodge them with the vacuum cleaner as mine does! (How many times have I come home to a blank picture or no audio..).
    Fman
