NTL Pace box -> video switching amp -> panny 5 = B&W
Discussion in 'Cable TV & Virgin Media TV' started by FaxFan2002, Jul 21, 2003.
  1. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,124
    63
    Andover
    +109
    Just got a Panny 5 and I've got the following setup / problem:-
    NTL (PACE) cable box -> SVIDEO -> Yamaha AMP -> SVIDEO MONITOR OUT -> Panny 5 VIDEO connection
    The output is Black and White which is slightly fuzzy. I *think* it maybe a RGB problem not sure - it did work fine on my old rear projection TV. Composite & SVIDEO work fine from other sources. Any NTL users out there who have had the same problem? - I will try via composite tonight and see what happens. I will also by trying comp. video with a pal progressive dvd player - can't wait!
    Thanks in advance,
    Robin.
    ooops, wrong forum...
  2. phenom2003
    phenom2003
    NTL boxes cannot output s-video so that's why you're getting a black and white image. You'll have to use composite for switching or use RGB scart to the tv.
